The Absolute Nodal Coordinate Formulation or the ANCF is a finite element based representation of flexible components
in one, two and three dimensions that are allowed to deform under applied load. It is a formulation that allows you
to model Non Linear Flexible Element (NLFE) components in your multibody system.
The implementation of the ANCF in MotionSolve allows you to create flexible components and attach them to the rest of your system in a similar way as rigid
bodies.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
The Absolute Nodal Coordinate Formulation or the ANCF is a finite element based representation of flexible components in one, two and three dimensions that are allowed to deform under applied load. It is a formulation that allows you to model Non Linear Flexible Element (NLFE) components in your multibody system.
