Load Maps
Use the Load Map tool to import/create multiple channels (load histories) which are then paired with subcases/loadsteps to create the fatigue events.
![](../../images/fatigue/load_case_dialog_w_events_and_subcases.png)
The information displayed in this dialog is dynamic. The available options change depending on the load type and the channel type.
Type of Loading | Channel Type |
Time Series | Time
Data Constant Amplitude Block Loading Duty Cycle (*.dcy) |
Transient Response | Transient Response |
Modal Superposition | Eigen Value
(*.pch) CMS (*.mrf) |
Random (PSD Stresses) | PSD Stress |
Random (Input PSD with FRF) | Input PSD: Phase and
Magnitude Input PSD: Real and Imaginary |
Sine Sweep | Constant Load Variable Scale |
