Altair Flux™ 2021.1.1 Documentation
2021.1
  1. Home
  2. Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
  3. Performing a simulation
  4. Results post-processing
  • User guide
  • What's new?
  • "How to" Documents
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • PyFlux Documentation (Beta version)
  • Flux installation guide
  • Quick Start CDE
2021.1
  • User guide
    The user guide gives information about principles and how to use Altair Flux™ 2021.1.
  • What's new?
    See the release notes of the last and previous versions, with the necessary information on new features.
    See a list of documents to understand how to use certain features.
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  • Flux Skew
    Flux Skew is a module allowing to facilitate the realization of a quasi 3D or 2 ½ D study starting from a 2D description.
  • Flux PEEC
    • Principles
    • Geometry construction
    • Performing a simulation
      • Physical description
      • Applications and electrical description
      • Solving process
      • Results post-processing
        • Results of "Conductors Impedance" application
        • Results of "Supplied Conductors (AC)" application
        • Paths
        • 2D grids
        • 2D curves
        • Isovalues
        • Isolines
        • Arrows
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
  • Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
    This document provides instructions for Flux installation on supported platforms.
  • Quick Start CDE
    This document guides you through using Computing Distribution Engine.
2021.1
  1. Home
  2. Flux PEEC
  • User guide
  • What's new?
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • Quick Start CDE
Contents
This chapter deals with following topics:
  • Paths
  • 2D grids
  • 2D curves
  • Isovalues
  • Isolines
  • Arrows
Copyright (c) 1983-2021. Altair Engineering, Inc. All Rights Reserved. Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication.
