Altair Flux™ 2021.1.1 Documentation
2021.1
  1. Home
  2. "How to" Documents
    See a list of documents to understand how to use certain features.
  3. How to set Flux for batch schedulers?
  4. Annex 1
  • User guide
  • What's new?
  • "How to" Documents
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • PyFlux Documentation (Beta version)
  • Flux installation guide
  • Quick Start CDE
2021.1
  • User guide
    The user guide gives information about principles and how to use Altair Flux™ 2021.1.
  • What's new?
    See the release notes of the last and previous versions, with the necessary information on new features.
    • How to Configure the Memory in Flux?
    • How to Drive Flux with Compose?
    • How to Experiment with NumPy in Flux?
    • How to Get the Steps of a Scenario?
    • How to import a HyperMesh mesh?
    • How to import a SimLab mesh?
    • How to Launch Flux via Command Line?
    • How to set Flux for batch schedulers?
      • The basics of Flux setup
      • Parametric distribution
      • Annex 1
        • Complete submission script (for PBS Pro)
        • Example of Flux2D script
    • How to Use External Jython Classes in Flux?
    • How to use Flux with PBS via Compute Manager?
    • How to Use Flux with PBS via Display Manager?
    • How to use the Flux-AcuSolve coupling with the Import/Export context?
    • How to use the Flux-OptiStruct coupling with the Import/Export context?
    • How to mesh skin effect?
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  • Flux Skew
    Flux Skew is a module allowing to facilitate the realization of a quasi 3D or 2 ½ D study starting from a 2D description.
  • Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
  • Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
    This document provides instructions for Flux installation on supported platforms.
  • Quick Start CDE
    This document guides you through using Computing Distribution Engine.
2021.1
  1. Home
  4. Annex 1
  • User guide
  • What's new?
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Examples
  • Mementos
  • Macros
  • Quick Start CDE
Annex 1
Copyright (c) 1983-2021. Altair Engineering, Inc. All Rights Reserved. Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication.
