Highlighting Specific Mesh Elements
The mesh highlight tool allows you to view areas of the mesh where specific model settings are applied.
On the 3D View contextual tabs set, on the
Mesh tab, in the Tools
group, click the Highlight icon. From the drop-down list select one of the following:
- None
- No mesh elements are highlighted.
- Lossy metal
- Highlight mesh elements (faces, wires) with a metallic medium and thickness applied to it.
- Coating
- Highlight mesh elements (faces, wires, edges) with a coating (layered dielectric) applied to it.
- CFIE / MFIE
- Highlight mesh elements (faces) with either a combined field integral equation (CFIE) or magnetic field integral equation (MFIE) applied to it.
- EFIE
- Highlight mesh elements (faces) with the electric field integral equation (EFIE) applied to it.
- Impedance sheet
- Highlight mesh elements (faces) with an impedance sheet applied to it.
- Surface impedance approximation
- Highlight faces that bound a region set to the dielectric surface impedance approximation.
- Physical Optics
- Highlight mesh elements (faces) with the physical optics (PO) solution method applied to it.
- Physical Optics (Fock regions)
- Highlight mesh elements (faces) with the physical optics (PO) solution method applied to a Fock region.
- Ray Launching GO
- Highlight mesh elements (faces) with the ray launching geometrical optics (RL-GO) solution method applied to it.
- Uniform Theory of Diffraction
- Highlight mesh elements (faces) with the uniform theory of diffraction (UTD) solution method applied to it.
- FEM
- Highlight mesh elements (regions) with the finite element method (FEM) solution method applied to it.
- VEP
- Highlight mesh elements (regions) with the volume equivalence principle (VEP) solution method applied to it.
- Windscreen solution elements
- Highlight mesh elements (faces, wires) that are specified as windscreen solution elements (windscreen antenna elements).
- Aperture
- Highlight a slot or aperture in an infinite plane with the planar Green's function aperture applied to it.
- Numerical Green's Function
- Highlight mesh elements defined as the static part using the numerical Green's function.
