Specify Points Manually
Define a time pulse by specifying the points manually.
Figure 1. Define a time signal by specifying the points.
Time axis unit
Specify the unit to be used for the time axis.
Scale time axis
A scale factor applied to the time axis values.
Scale amplitude
A scale factor applied to the amplitude axis values.
[Time, Amplitude]
Specify the Time (X) and Amplitude (Y) coordinates of the time signal. The pulse will be resampled using number of specified samples, where linear interpolation between the defined points will be used.
Note: The list of points can be imported from any comma separated value file.
Number of samples
The number of samples taken from the signal’s analytical equation.
