Create a time signal to analyse frequency domain results in the time domain. A list
of predefined time signals are available.
Obtain a frequency domain solution over the required bandwidth for the relevant
requests.
On the Time analysis tab, in
the Time signal group, click the
New time signal icon.
On the Create time signal dialog, from the
Signal type
drop-down list, select one of the following time signals:
- Define pulse mathematically
- Double exponential difference pulse
- Double exponential piecewise pulse
- Gaussian pulse (normal distribution)
- Ramp
- Specify points manually
- Triangular pulse
Figure 1. The Create time signal dialog.
Modify the time signal parameters to adjust the time signal.
Click Create to create the time signal and to
close the dialog.
