A report template can be exported to XML format for reuse in another POSTFEKO session.
On the Reporting tab, in the
Reports group, click the Import / Export template icon. From the drop-down list select the Export report template (*.xml) icon.
Figure 1. The Export report template dialog.
From the Report templatedrop-down list, select a defined report template.
In the File name field enter a file name to be used for
the exported template.
Click OK to export the report template and to
close the dialog.
