Cartesian Surface Graphs
A Cartesian surface graph is a flat colour plot with results plotted against two independent axes.
Figure 1. Example of a near field displayed on a Cartesian surface graph.
The surface graph allows you to plot quantities like radar cross section (RCS), gain or near fields as a function of two as a function of two independent parameters, such as angles theta and phi or frequency and position.
Note: Only a single plot per Cartesian surface graph is supported.
Table 1. Result types that can be viewed on a Cartesian surface graph.
Result type Cartesian surface graph
Far fields (including RCS)
Near fields
Error estimates
Currents
Rays
Sources
Loads
S-parameters
Power
Probes
Transmission / reflection coefficients
Characteristic modes
Imported data
Script data / custom datasets
Optimisation
Receiving antenna
SAR
