Specify the number of contours and its location on a 3D result to view points of
equal value.
Enable the display of contours.
On the 3D View
contextual tabs set, on the Result tab, on the
Contours group, click the Show contours icon.
On the 3D View
contextual tabs set, on the Result tab, in the
Contours group, click the Position icon.
Figure 1. The Contour positions dialog.
Select one of the following workflows:
To specify the number of contours, select Number of
contours. The contour values are evenly distributed over the
result range.
To specify the number of contours coincident with a specific location,
select Specify contour values. The contour location
can either be defined by its magnitude value, or by specifying a percentage
of the value range.
