Solve a cylinder with the uniform theory of diffraction (UTD). The cylinder can either be a finite, semi-infinite or
infinite, depending on the termination type of the start cap and end cap.
Create a cylinder.
Select the cylinder in the 3DÂ view or in the details tree.
In the details tree, from the right-click context menu, select Properties.
On the Region properties dialog, click the
Solution tab.
Under Solve with special solution method, from the
drop-down list, select Uniform theory of
diffraction (UTD) cylinder.
Under Termination type, specify if the UTD cylinder is infinite or finite sized at the
start cap.
To define a finite cylinder, select the Start cap
check box.
To define an infinite cylinder, clear the Start
cap check box.
