Modify an item in a union. The union may contain multiple multi-level unions. Parts
inside unions can be edited directly, as an example, changing the height of a cuboid. When
more complex editing is required (setting properties on faces), the part should be copied
out, edited and placed back into the union.
In the model tree, find the relevant union that you want to
edit.
Under the union, select the part that you want to edit.
From the right-click context menu, select Copy
(duplicate).
Edit the duplicate part.
In the model tree, drag the modified part back into the
union of Step 2.
Replace.
You can replace a part with a completely different part. For example, replace
a cuboid with a flare or sphere.
