Model Unit
The model unit specifies the unit that is used for all dimensions in the model.
When you modify the model unit, the unit does not modify any numbers specified in CADFEKO, but rather the internal interpretation of all numbers created
before and after the unit change.
Note: You may change the model unit at any stage during and
after the construction of the model.
The model unit is specified at the following locations:
- Home tab, in the Model attributes group
- Construct tab, in the Define group
- Status bar
