Preconditioners for MLFMM
A number of preconditioners are available when using the multilevel fast multipole method (MLFMM) (for advanced users only).
Note: It is recommended to use the default settings.
On the Solve/Run tab, in the
Solution settings group, click the
Solver settings icon. On the Solver setting dialog, click the
Advanced tab.
Figure 1. The Solver settings dialog (Advanced tab).
- Block-Jacobi using LU-decomposition (64)
- Preconditioner for an MLFMM solution where the
inverses of the preconditioner are calculated and applied during every iteration
step.Note: Due to performance reasons, this is the recommended preconditioner.
- Incomplete LU decomposition (ILU) (128)
- Preconditioner for an MLFMM solution that uses an incomplete LU-decomposition of the matrix.
- Multilevel FEM-MLFMM LU/diagonal decomposition (2010)
- Preconditioner for a hybrid FEM / MLFMM solution that uses a multilevel sparse LU
decomposition of the combined and partitioned system.
When using the parallel Solver, the factorisation type can be specified.
- Block-Jacobi preconditioner of MLFMM one-level-up (4096)
- Preconditioner for an MLFMM solution that uses LU-decomposition on entries in the boxes, one-level-up from the finest boxes.
- Sparse approximate inverse (SPAI) (8192)
- Preconditioner for an MLFMM solution.
- Sparse LU (8193)
sparse LU decomposition of the MLFMM near field
matrix.
Note: The number in brackets corresponds to the value of the I3 field at the CG
card.
