Creating an Anisotropic Layered Dielectric (2D)
Create an anisotropic-layered dielectric.
- On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select Anisotropic layered dielectric (2D) icon.
In the Label field, enter a
unique label for the dielectric.
- In the Thickness field, enter a value for the layer thickness.
- In the Principal direction (deg), enter the angle of the principal direction.
In the Material in principal direction field, select one
of the following:
- To add a dielectric layer in the principal direction, consisting of a predefined dielectric, select the dielectric.
- To add a dielectric layer in the principal direction consisting of a dielectric, which is not yet defined in the model, click the icon to define the dielectric or add a dielectric from the media library.
In the Material in orthogonal direction field, select
one of the following:
- To add a dielectric layer in the orthogonal direction consisting of a predefined dielectric, select the dielectric.
- To add a dielectric layer in the orthogonal direction consisting of a field, which is not yet defined in the model, click the icon to define the dielectric or add a dielectric from the media library.
- [Optional] To add an additional layer, click Add.
- [Optional] To remove a layer, click Remove.
