Example: Cable Reference Direction - Connected to an Installation
Consider an example where a cable path is defined within a distance of from a ground plane.
The cable cross section orientation is indicated by:
- dotted green line: vector
- blue line: vector
- solid dark green line: cable reference direction
Note: CADFEKO tries to orientate the
vector at the start of the cable path to align
with the cable reference direction automatically using the constraint that the
and
vector must be perpendicular to the cable path.
The cable reference direction is defined normal to the installation or ground (in the
“up” direction) and is not pointing towards it. In the cable schematic the
cable is connected to the installation
and acts as a return path for the signal. No twist
angle is defined along the cable path.
Figure 1. Specify the cable reference direction above a ground plane.
Note: This option can be used with only one signal in the cable harness as the
installation acts as the return path.
