Placing Geometry on Objects (Align)
Align an object onto another object, for example, placing an antenna onto a ship.
- Select the geometry part that you want to align relative to another part.
On the Transform tab, in the
Transform group, click the
Align icon.
Figure 1. The Align dialog. -
Under Source workplane, specify the following:
- Under Origin, specify the origin for the source workplane.
- Under U vector and V vector, specify the workplane orientation.
- Under Rotate workplane, specify the angle to rotate the workplane by.
- Repeat Step 3 for the Destination workplane.
- Click OK to create align the selected geometry part and to close the dialog.
