Card Panel
The card panel contains the full card definition and provides editing of the card parameters.
Press F1 on a card to highlight the card entry in the editor area and display the full card definition in the card panel. A new card can be created by clicking on the corresponding button on the ribbon.
Card panels make it easy to edit cards and enter data in the correct card fields. The panels support cards that span multiple lines and they automatically use the correct card format (column or colon delimited). Once the panel has been populated with the data, click on OK to apply the changes, write the card and close the panel.
- Click the OK button to add the card to the .pre file and close the card panel.
- Click the Add button to add the card to the .pre file, but keep the card panel open.
