Delete Nodes
Nodes defined in the project can be deleted either directly via the Nodes tab of the System Configuration dialog or by using the Node Delete Tool.
With the Node Delete Tool a node can be erased with the mouse. The Node Delete Tool can be accessed by selecting from the Project menu or by pressing the corresponding button on the Project toolbar. A further possibility is to use Delete from the context menu of the 2D View if the node to be erased is already selected.
If the tool is started, the mouse cursor changes and the node to be deleted can be specified graphically with the mouse using the context menu.
