Example Functions
The general syntax for any Java function can be summarized as:
<output> <functionName> ( <inputs> ) {
  // Comment Add your Java code here
The next elements are identified:
  • Output It specifies the type of data that the function will return. The most common type will be double or double [], that is, real numbers or arrays of real numbers.
  • functionName Name that defines the function. This name is used to invoke the function.
  • inputs Arguments required for invocating the function. Any type of argument is allowed, for example "()" for empty arguments; "(int n)" for an integer argument; or "(double start, double end, int samples)" for a real range defined by its boundary values and the number of samples."
Multiple functions are included in the following:
Function examples:
 // Calculate the square of 'a'
 double square(double a){
  return a*a;
 // Calculate the modulus of vector (x,y,z)
 double modulusVector(double x, double y, double z){
  return Math.sqrt(x*x + y*y + z*z);
 // Calculate if 'a' is prime
 int prime(int a){
  // returns 1 if 'a' is prime, else return 0
  for(int i=2 ; i<=(a/2) ; i++) {
   if(a % i == 0) {
    return 1;
  return 0;
 // Calculate the a-th number of the Fibonacci sequence
 int fibonacci(int a){
  int fib_n = 1;  // fibonacci(0)
  int fib_m = 1;  // fibonacci(1)
  int fib_i;
  if (a < 0) {
   return 0;
  if (a < 2) {
   return 1;
  for(int i=2 ; i<=a ; i++) {
   // calculate fibonacci(i)
   fib_i = fib_n + fib_m ;
   fib_n = fib_m;
   fib_m = fib_i;
  return fib_i;
 // Calculate the 'a' factorial (a!)
 double factorial(int a){
  double acc = 1;
  for(int i=1 ; i<=a ; i++) {
   acc = acc * i;
  return acc;
 // Calculate the binomial coefficients function
 double binomial(int m, int n){
  return (factorial(m)) / (factorial(n) * factorial(m-n));
