Creating the Finite Substrate
Create a finite substrate by creating a cuboid. Set the region of the cuboid to the medium, substrate.
Create the cuboid.
On the Construct tab, in the Create solid group, click the
Cuboid icon.
- Create the cuboid using the Base corner, width, depth, height definition method.
Note: Primitives, such as the cuboid, have more than one definition method. The cuboid can also be defined as Base centre, width, depth, height.-
Use the following dimensions:
Dimension Value Base corner (C) (-substrate_w/2, -substrate_d/2, -substrate_h) Width (W) substrate_w Depth (D) substrate_d Height (H) substrate_h - Click the Create button to create the cuboid and to close the dialog.
Change the cuboid to a dielectric cuboid.
- Select Cuboid1 in the model tree.
In the details tree open the right-click context menu and select
Properties.
Set the Region medium to
substrate.
Note: This is the substrate dielectric medium created at the start of the example.
Click OK to close the dialog.
