Create Indoor Pre-Processing Project
The prerequisite for the creation of an indoor pre-processing project is a raw binary vector indoor database file (.idb).
To create the project, select WallMan will ask for a .idb file that contains the database to be pre-processed. Select the file and click OK to close the dialog. WallMan now shows the database. Although this looks like the database edit mode it is not possible to change the database.
from the menu.![]() |
The pre-processing parameters dialog can be opened via the button in the toolbar or via in the menu. |
Start the pre-processing by clicking on the button in the toolbar or by selecting WallMan will ask for a name for the project file before the pre-processing starts. in the menu. |
