WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications
ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning
to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output
(MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine
the actual antenna pattern while taking into consideration the local environment.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models
as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks,
ICNIRP and EM compliance.
Select a building by clicking on the outline of the building.
A selected object is indicated in red.
Figure 1. A selected building is indicated in red. Top view of Frankfurt (on
the left) and 3D view (to the right).
Right-click on the selected building and from the right-click context menu, click Properties.
The Object Properties dialog is displayed.
Figure 2. The Object Properties dialog.
Verify the building type of the selected building.
Next to Object, click Change
Type.
Under Selected Type, verify that
Standard Building1 is
selected.
Figure 3. The Wall Type dialog.
Click OK to close the Wall
Type dialog.
Under Corners, select a corner and click
Edit to modify the height of the building.
The Enter Coordinates dialog is displayed.
Figure 4. The Enter Coordinates dialog.
In the Z field, enter a new height for the
building.
Click OK to close the Enter
Coordinates dialog.
Click OK to close the Object
Properties dialog.
The height of the selected building is updated.
Figure 5. The height of the selected building is increased.
1 Other building types
also supported are: horizontal plates, courtyards and towers,
vegetation block and virtual buildings, see the WinProp User Guide for more information.
