Adding an Angled Prediction Plane
Define an additional and arbitrary polygonal prediction plane.
![](../../../../images/winprop/getting_started_guide/example1/image_isometric_view_prediction_plane.png)
Figure 1. A 3D model of the building showing the additional prediction plane to be added to the model (indicated with a blue outline).
Create a polygon using one of the following workflows:
- On the Objects menu, click Enter Basic Objects > Enter Polygonal Object.
- On the Objects toolbar, click
the
Add Polygonal Objects icon.
- Press F7 to use the keyboard shortcut.
Create the general shape of the prediction plane (in this example, a
rectangle).
Figure 2. View of the model in the X/Y plane (top view). The general shape of the prediction plane is illustrated in green.- Click twice to specify the first corner of the polygon.
- Click twice to specify corner 3 and corner 4.
- Right-click at the first corner to close the polygon.
Edit the coordinates of the prediction plane.
- Select the prediction plane by clicking on the outline of the polygon.
- Right-click on the selected prediction plane and from the right-click context menu, click Properties.
On the Object Properties dialog, specify the
precise coordinates:
- (-11, 6, 4)
- (8, 6, 4)
- (8, -5, -1)
- (-11, 5, -1)
Click Change Type.
The Wall Type dialog is displayed.
Under Selected Type, from the drop-down list, select Prediction
Plane.
Figure 3. The Wall Type dialog. - Click OK to close the Wall Type dialog.
Click OK to close the Object
Properties dialog.
Figure 4. A 3D model of the building showing the angled prediction plane (indicated with a blue outline).Note: The new prediction plane must also be included in the simulation when setting up the project parameters in ProMan, see Step 5.
