Example Model
An MRI birdcage model is used as an example to demonstrate the application macro that plots multiple S-parameter traces.
The birdcage MRI coil has two ports at the bottom rung. They are excited with equal magnitudes and 90° phase difference. Both rungs have sixteen equal-value capacitors, which tune the resonance of the system. The diameter of the coil is 30 cm. Around the coil is a cylindrical shield. The birdcage coil is aligned with the Z axis.
<FEKO_SHARED_HOME>/installedapplicationmacrolibrary/POSTFEKO/PlotMultipleSParameterTraces/examples.
