View the far field results on a polar graph.
Since a full 3D set of data is requested in this example, 2D cuts can be
extracted.
Create a new polar graph.
On the Home tab, in the
Create new display group, click the Polar
icon.
Add the far field result to the polar graph.
On the Home tab, in the Add results group, click the
Far field icon. From the drop-down list, select
FarField1.
View the far field gain plotted in the YZ plane.
On the result palette, in the Slice
panel, make the following changes:
From the Independent axis (Angular) list, select
Theta (wrapped).
From the Frequency
1.645 GHz.
From the Phi list, select 90 deg
(wrapped).
On the result palette, in quantity panel panel, select the dB check box.
View the total gain.
