Script
View the script used to configure a session and export a report that highlights the antenna properties of the model.
AUTOMATIC QUICK REPORT GENERATION FOR ANTENNA PATTERN ANALYSIS
This script loads the specified model. It then creates various
views and graphs that display the far field pattern. These
views are then exported to a PDF report
modelName = {}
modelName[1] = "Horn"
modelName[2] = "Patch"
-- Get user input through Forms
form = pf.Form.New("Select model")
comboBox = pf.FormComboBox.New("Model name", modelName)
form:Add(comboBox)
form:Run()
index = comboBox.Index
app = pf.GetApplication()
app:NewProject()
app:OpenFile(modelName[index]..".fek")
selectedModel = app.Models[modelName[index]]
selectedConfig1 = selectedModel.Configurations[1]
ffData = selectedConfig1.FarFields[1] -- This is a handle on the far field data itself
view3D = app.Views[1]
ffPlot = view3D.Plots:Add(ffData)
ffPlot.Label = "ff3D"
ffPlot.Quantity.ValuesScaledToDB = true
view3D_top = view3D:Duplicate()
view3D_top:SetViewDirection(pf.Enums.ViewDirectionEnum.Top)
view3D_right = view3D:Duplicate()
view3D_right:SetViewDirection(pf.Enums.ViewDirectionEnum.Right)
view3D_front = view3D:Duplicate()
view3D_front:SetViewDirection(pf.Enums.ViewDirectionEnum.Front)
polarGraph = app.PolarGraphs:Add()
ffTracePhi_00 = polarGraph.Traces:Add(ffData)
ffTracePhi_00.IndependentAxis = "Theta (wrapped)"
ffTracePhi_00.Quantity.ValuesScaledToDB = true
ffTracePhi_90 = polarGraph.Traces:Add(ffData)
ffTracePhi_90.IndependentAxis = "Theta (wrapped)"
ffTracePhi_90.Quantity.ValuesScaledToDB = true
ffTracePhi_90:SetFixedAxisValue(ffTracePhi_90.FixedAxes[2],90,"deg")
polarGraph:ZoomToExtents()
polarGraph.Title.Text = "Gain"
polarGraph.Legend.Position = pf.Enums.GraphLegendPositionEnum.OverlayTopRight
polarGraph.BackColour = pf.Enums.ColourEnum.LightGrey
polarGraph:Restore()
quickReport = app:CreateQuickReport(modelName[index].."AntennaQuickReport",
pf.Enums.ReportDocumentTypeEnum.PDF)
quickReport.DocumentHeading = modelName[index]..[[ Antenna:
Automated Quick Report]]
quickReport:SetPageTitle(view3D.WindowTitle, "Isometric View")
quickReport:SetPageTitle(view3D_top.WindowTitle, "Top View")
quickReport:SetPageTitle(view3D_right.WindowTitle, "Right View")
quickReport:SetPageTitle(view3D_front.WindowTitle, "Front View")
quickReport:SetPageTitle(polarGraph.WindowTitle, "Theta Cuts")
quickReport:Generate()
