Calculate the bistatic radar cross section of an electrically thin dielectric sheet. The sheet is modelled using the
thin dielectric sheet approximation and is illuminated by an incident plane wave.
Calculate the transmission and reflection coefficients for a Jerusalem cross FSS (frequency selective surface) structure.
The cross is modelled with a periodic boundary condition and is excited with an incident plane wave.
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation
in the Solver.
Calculate the transmission coefficient of a second order, electrically thin bandpass FSS (frequency selective surface)
structure. The structure is modelled with a periodic boundary condition and is excited with an incident plane wave.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO
(large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
View the total computed transmission and reflection coefficients.
Compare the results with the literature reference, Ivica Stevanovic, Pedro
Crespo-Valero, Katarina Blagovic, Frederic Bongard and Juan R. Mosig,
Integral-Equation Analysis of 3-D Metallic Objects Arranged in 2-D Lattices Using
the Ewald Transformation, IEEE Trans. Microwave Theory and Techniques, vol. 54, no.
10, October 2006, pp. 3688–3697.
