Meshing the Model
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
- Set the Mesh size equal to Custom.
- Set the Triangle edge length equal to 4 cm.
- Set a 3 cm local mesh size on the region inside the elliptical phantom.
- Mesh the model.
