Define the Blank Type and Material
Identify the blank type in your model as single or tailor-welded, and assign a material to the blank.
Create User-Defined Materials
Create a material that is based on user-specified values.
Import Materials
Import materials in the My Materials tab.
Create and Assign a Material Based on Test Data
Create a new material with test data from a .xlsx file.
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Add/remove from selection | Ctrl+click |
| Reverse selection | Ctrl+R |
