Node Tool
Use the Node tool to add new node objects to the database.
Once the  Node tool is selected, click with the left mouse button where you want the node to appear. You can modify the Z-coordinate of the node in the Object Properties dialog or by moving the node in the side view window using the Edit tool. There are two types of nodes in TuMan:
  1. Portal nodes
  2. Standard nodes
