Cross Section List
The cross section list gives an overview of all available cross section geometries within the current project. The user has the possibility to manage the listed cross sections by using the buttons on the right side of the dialog:
Figure 1. The Available cross section geometries dialog.
Edit
Closes the dialog and activates the Cross Section View of the selected cross section geometry.
New
Creates a new cross section geometry. A dialog appears to name the new cross section.
Copy to
Copies the contents of the highlighted cross section geometry into another. TuMan displays a Select Cross Section dialog to select the target.
Load
Loads a cross section geometry from disk.
Save
Saves the selected cross section geometry to disk. A Save As dialog will be displayed to name the file.
Rename
Renames the selected cross section geometry. A dialog appears to enter the new name, which must differ from the existing ones.
Delete
Removes the selected item from the list and deletes the cross section geometry, if you confirm.
Warning: This action cannot be undone.
Close
Closes the dialog.
To open the Cross Section List dialog, use the Cross Section List command in the Edit menu or press F8 key.
