UWB
View the settings for ultra wide band.
Air Interface Parameters
All parameters related with a selected air interface can be specified on the Air Interface tab of the Edit Project Parameter dialog. For ultra wide band mode, the following settings are available:
Figure 1. The Edit Project Parameters dialog, Air interface tab.
Duplex Separation
Duplex separation is fixed to simplex, thus only downlink direction is possible.
MIMO Technology
MIMO technology is not supported for this air interface.
Channel Bandwidth
Available bandwidth of the channel. This value is used to calculate thermal noise impact.
Carrier Separation
Frequency separation of two adjacent carriers. This value is used for determination of adjacent or co-channel interference.
Output Options
Results based on the Analysis of the Carriers
  • Number of Carriers received
