Fifth Generation (5G) Cellular Network
Air Interface Parameters
All parameters related with a selected air interface can be specified on the Air Interface tab of the Edit Project Parameter dialog.
Note: The 5G keyword in the .wst file enables the 5G relevant settings on the Edit Project Parameter dialog.
Figure 1. The Edit Project Parameters dialog, Air interface tab.
Bandwidth
Important 5G-specific settings are the Channel Bandwidth and the Numerology. The Channel Bandwidth is the total frequency range spanned by all the sub-carriers, and the numerology governs the sub-carrier spacing. These settings are only available in projects that have the 5G keyword in the .wst file. The 5G keyword also affects some options in the OFDM/OFDMA settings (see OFDM / SOFDMA (Downlink and Uplink)) and on the Carrier dialog.
