Office Building with Antenna and Radiating Cable
Compute the indoor propagation in a multi-story office building with a single antenna, and a radiating cable is placed on the ground story.
Model Type
The building has five stories, which include the ground floor. The simulation is done for only one prediction height at 1.5 m above the ground.
Sites and Antennas
There are two sites at different locations in the office building:
  • Site 1 has a dipole antenna operating at 2.4 GHz at a height of 2.5 m.
  • Site 2 has a radiating cable installed.
Figure 1. The office building layout.
Tip: Click Project > Edit Project Parameter and click the Sites tab to adjust the cable parameters.
Computational Method
As the office building consists of several stories, the computation method is the dominant path model (DPM). DPM focuses on the most relevant path, which leads to shorter computation times compared to standard ray tracing model (SRT). The radiating cable has gaps (slots) in its outer sheath to allow the signal to radiate along its entire length. Therefore a special prediction model is used to predict wave propagation. The shortest distance model predicts the received power using the shortest geometric distance between the radiating cable and the receiving point.
Results
Figure 2 and Figure 3 show the propagation results received at Site 1 and Site 3 from each transmitting antenna individually.
Figure 2. The received power from Site 1.
Figure 3. The received power from Site 2.
