Optimization, Urban, Antenna Adjustment
Optimize the azimuth angle of the tilt of a base-station antenna.
Optimization Overview
During the installation of new radio networks, it is often difficult to find the optimum azimuth and tilt of every base-station sector antenna. With OptMan, you can find the best radio coverage by adjusting azimuth and tilt of a given set of antennas and sites. First, define a radio-planning project with ProMan, including all sites and antennas. Based on any specified network-planning result type, for example, data rate, signal level, interference level, or similar and corresponding optimization target definitions, OptMan finds the best antenna azimuths and tilts to fulfill these specified targets or approach the defined targets as close as possible.
Model Type
The ProMan project is an example of a network planning project for an urban scenario.
Sites and Antennas
Figure 1. Urban database with three antenna sites in ProMan.
In OptMan, the antennas (transceivers) are listed, as shown in Figure 2. This is the list before optimization.
Figure 2. Transceiver list in OptMan.
At the beginning of the optimization, the antennas to be varied have the check mark Consider for Optimization in the settings at the bottom of the list, and they have the green dot in the ID column.
Optimization Target
Figure 3. Optimization chart.
Results
Figure 4. Optimization results.
Figure 5. Best SNIR result for QPSK modulation.
