Pan, Zoom, Orbit, Rotate, and Look Around
Pan, zoom, and orbit in the 2D orthographic views and the 3D perspective view.
  2D Orthographic Views 3D Perspective View
Pan Drag with the right mouse button.
Mac track pad: Two finger click + drag.
Ctrl (Command) + drag with the right mouse button.
Zoom centered on the mouse cursor Use the scroll wheel on the mouse.
The center of the zoom is determined by your cursor position.
Zoom about the screen center
Ctrl (Command) + Shift + drag with the right mouse button
Mac track pad: Two finger tap + drag.
Orbit around the object N/A Drag with the right mouse button.
Trackball rotate Drag with the middle mouse button. Ctrl (Command) + drag with the middle mouse button.
Turntable rotate Shift + drag with the right mouse button.
Set center of rotation and use trackball to rotate Shift (+ Command) + drag with the right mouse button.
Look around Drag with the left and right mouse buttons.
Note: Inspire Studio provides a default preset for certain mouse controls found in Preferences. Modify the default at will.
