The software saves versions of your objects as you create them, enabling you to return to an earlier stage of an object,
and modify or reuse the object from that stage.
Capture an image of a model. The background is white by default, but you can make it colored or transparent. Arrows
on curves are automatically turned off.
Inspire Studio has four different tool belts to help you quickly access the tools you need for 3D modeling, sketching, creating
PolyNURBS, and rendering. You can use the tool belts with the default configuration of tools or you can customize
the tool belts by adding and removing tools as required.
Create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease and simplicity
of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form solid
geometry that is smooth and continuous.
Measure dimensions, analyze curvature, check for continuity and watertightness, analyze the draft, detect undercuts,
and create design iterations on the fly.
Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined
dimensions. You can also insert a general annotation to label the parts of your model.
Change the default units and measure geometry features.
Change the Default Units
In Inspire Studio, the default unit of measurement is centimeters. You can also choose from millimeters, meters, inches, and feet.
Measure Features
Measure geometry features including a length, an angle, a radius, a diameter, and the dimensions of a bounding box.
