User Guide: Altair  Inspire Studio 2021
  1. Home
  2. What's New
    Discover new features and enhancements.
  3. Release Notes 2020
  • What's New
  • Get Started
  • Tutorials
  • Sketching
  • Curves
  • Surfaces
  • PolyNURBS
  • Modify
  • Direct
  • Deform
  • Analysis
  • Dimensions
  • Drawing
  • Rendering
  • Animation
  • Die Design
  • Custom Plug-ins and Scripts
  • Keyboard Shortcuts and Mouse Controls
Index
  • What's New
    • What's New in Inspire Studio
      Get a quick overview of what's new in Inspire Studio, in PDF format.
    • Release Notes 2020
      • Altair Inspire Studio 2020.1.2
      • Altair Inspire Studio 2020.1.1
      • Altair Inspire Studio 2020.0.1
    • Release Notes 2019
  • Get Started
    New to Inspire Studio? Learn the basics here.
  • Tutorials
    Start using Inspire Studio with our interactive tutorials.
  • Sketching
    Create and edit a 2D sketch curve. A sketch curve is any "wire" entity such as a line, rectangle, circle, or arc.
  • Curves
    Create and edit 3D curves by extending, rebuilding, intersecting, splitting, and projecting the shapes.
  • Surfaces
    Create and edit 3D surfaces and solids by creating primitives or editing existing curves and surfaces.
  • PolyNURBS
    Create polygonal surfaces that can easily be converted into NURBS surfaces. PolyNURBS combines the ease and simplicity of polygonal modeling with the precision and flexibility of NURBS, allowing you to quickly create free-form solid geometry that is smooth and continuous.
  • Modify
    Create new objects by manipulating and modifying source objects.
  • Direct
    Quickly modify objects that are not a part of Construction History.
  • Deform
    Deform one or more objects with respect to an axis.
  • Analysis
    Measure dimensions, analyze curvature, check for continuity and watertightness, analyze the draft, detect undercuts, and create design iterations on the fly.
  • Dimensions
    Dimension a line, edge, bounding box, angle, and radius/diameter in order to create objects which must fit predefined dimensions. You can also insert a general annotation to label the parts of your model.
  • Drawing
    Create detailed 2D drawings of the selected parts of a complex 3D model from multiple perspectives.
  • Rendering
    Adjust the materials, environment, and properties of objects in the scene to create a photorealistic image.
  • Animation
    In Inspire Studio you can animate an object or group and the camera. There are two methods of animation: key frame animation and path animation.
  • Die Design
    Create a draw die in Inspire Studio that you can export to Inspire Form to perform a stamping simulation.
    You can use C++ and Python to add custom operations and file formats.
    Learn keyboard shortcuts and mouse controls for common operations.
  1. Home
  2. What's New
  • What's New
  • Get Started
  • Tutorials
  • Sketching
  • Curves
  • Surfaces
  • PolyNURBS
  • Modify
  • Direct
  • Deform
  • Analysis
  • Dimensions
  • Drawing
  • Rendering
  • Animation
  • Die Design
Index
Release Notes 2020
(c) Altair Engineering, Inc. All rights reserved.
