Set up your model parts, materials, nozzle paths, tooling and process parameters prior to analysis.
Vents enable gases to escape from the part and mold.
Discover new features and enhancements.
New to Inspire PolyFoam? Learn the basics here.
Start using Inspire PolyFoam with our interactive tutorials.
Create and modify sketch curves, surfaces, and solids.
The nozzle releases the foaming material into the mold through a set of injection points that are stationary or situated on a path.
Add line vents to enable gases to travel along the part and escape from the parting line of the mold.
Add point vents to enable gases to escape from around the part and through the exterior of the mold.
The process parameters define the ending conditions for the filling and gelling processes of the analysis. Advanced parameters define the tilt-pouring process.
Run an analysis to minimize defects and prevent manufacturing problems for a foam part design.
