Altair® Panopticon
Create Task to Extract Data
Tasks can be created to reload workbook or global extracts.
1.     On the New Task pane, enter the Name of the task and click . Ensure the name is unique.
2.     Tap the Activated slider to turn it on.
3.     Select the Trigger. You can either select:
·         Period then enter the Interval (in seconds), or
·         CRON then enter the CRON Expression
4.     Select the task Type: Extract Data.
5.     Enter the Description of the task.
6.     Select the data extract to be scheduled in the Extract Name drop-down list box. The list is taken from the data extracts list on the Extracts tab.
7.     Click .
Click  to go back to the Tasks pane. The new task is added in the list.
