Altair® Panopticon
Creating Data Extract from Rserve
The Rserve connector allows the retrieval of an output data frame from a running Rserve process.
For R connectivity, R must be first installed, together with the Rserve library.  In addition, R must be open, and the Rserve library must be loaded and initialized.
1.     On the New Data Extract page, select Rserve in the Connector drop-down list.
2.     Enter the following properties:
Property
Host
Rserve host address.
Port
Rserve host port. Default is 6311.
User Id
The user Id that will be used to connect to the Rserve service.
Password
The password that will be used to connect to the Rserve service.
3.     Enter the required R script to execute on the active Rserve instance.
4.     Enter the Timeout. Default is 10 (in seconds).
5.     Select whether the parameters should be automatically enclosed in quotes by checking the Enclose parameters in quotes box.
6.     Click    to save and display the details of the data extract.
7.     Click   then   to display the data preview.
