Using SVG Files with Altair Panopticon Designer - Desktop Edition
Panopticon Designer (Desktop) is shipped with a connector for SVG files, which can provide for example:
Maps for Choropleth map visualizations (http://en.wikipedia.org/wiki/Choropleth_map)
Store plans for visualization of crowd flows, client interaction volumes, and so on
Schematic drawings of process industry facilities for hardware performance monitoring
In Panopticon Designer (Desktop), the SVG XML is translated and the rendering is done by Panopticon Designer (Desktop). For this reason, Panopticon Designer (Desktop) does not support the full scope of the SVG standard definition.
The only element supported is PATH: http://www.w3.org/TR/SVG/paths.html
In the d-attribute of the PATH element, the following commands/instructions are supported (both Absolute (upper case) and Relative (lower case):
M,m: http://www.w3.org/TR/SVG/paths.html#PathDataMovetoCommands
Z,z: http://www.w3.org/TR/SVG/paths.html#PathDataClosePathCommand
L,l: http://www.w3.org/TR/SVG/paths.html#PathDataLinetoCommands
H,h: http://www.w3.org/TR/SVG/paths.html#PathDataLinetoCommands
V,v: http://www.w3.org/TR/SVG/paths.html#PathDataLinetoCommands
C,c: http://www.w3.org/TR/SVG/paths.html#PathDataCubicBezierCommands
S,s: http://www.w3.org/TR/SVG/paths.html#PathDataCubicBezierCommands
For example, in order to be rendered this means that a circle must be drawn using the PATH element with a couple of C or S commands. Adding the following XML section to the Worldmap.svg file shipped with Panopticon Designer (Desktop) will produce a circle in the North Sea, right between the UK and Sweden:
<g id="Circle Example">
<path class="SamplePath"
d="M523,118 c0,-10 15,-10 15,0 c0,10 -15,10 -15,0"/
</g>
In the above example, we are using M for absolute coordinates to begin with. Then we use lower case c for relative move compared to the initial coordinate provided by M.
The reference point remains the same within the full extent of a command. This means that when the first c-command is done, and the second c-command starts, the reference point has changed from 523,118 (provided by M) to be 538,118 (equaling the initial starting point plus the relative coordinates specified lastly in the first c-command).
