Altair® Panopticon™
Special Server Parameters
Panopticon supports the following built-in parameters with special usage. These are all case sensitive and include:
  Parameter Name
Descritpion
Value
Old Name
Old Value
_current_time
Returns the Date/Time of the current time with millisecond precision. 2020-06-04T16:58:48Z CurrentTime 2020-06-04T16:58:48Z
_dashboard_name Returns the name of the dashboard. SysParamsDashboard
_datatable_name Returns the name of the data table. 42d8cd06-a99f-4a54-8f1b-378585cf…
_datatable_title Returns the title of the data table. SysParamsTable
_last_workday
Returns the last business Date/Time with millisecond precision (excludes Saturdays and Sundays). 2020-06-03T16:58:48Z
LastWorkDay
_quarter_start
Returns the date of the most recent start/first day of the quarter period (i.e., 1st January, 1st April, 1st July, 1st October) with the time set to midnight. 2020-04-01T00:00:00Z
QuarterStart
_user_id
The username stripped of domain information and converted into lower case. (If it contains a back slash, only the part after the first back slash is returned.)
The _user_id parameter can then be used as the basis for a data query filter clause, limiting the returned results to be specific to the user’s profile.
stefan_odelfalk
userid
stefan_odelfalk
_user_name
Returns the username exactly as it appears in the Identity.
DWCH\Stefan_Odelfalk
username
_week_start
Returns the current Date/Time with millisecond precision of the most recent Monday.
2020-06-01T16:58:48Z
WeekStart
_workbook_folder
Returns the workbook folder.
examples\
_workbook_name
Returns the workname name.
SysParamsWorkbook
Other special usage parameters relate to time series analysis and the use of the time filter box which including the following:
  • TimeWindowStart
  • TimeWindowEnd
  • Snapshot
When the time filter box handles are moved to filter on a time window, these special parameters will automatically receive the updated Date/Times, in ISO UTC format.
For example:
Produces:
TimeWindowStart       = 2008-01-02T00:00:00Z
TimeWindowEnd         = 2009-03-06T00:00:00Z
Snapshot                    = 2008-11-14T00:00:00Z
For example:
Produces:
TimeWindowStart         = 2008-03-26T16:17:13Z
TimeWindowEnd           = 2009-01-09T17:50:47Z
Snapshot                      = 2008-12-22T00:00:00Z
These parameters can then be used as appropriate to restrict the amount of time series data returned in the resultant dataset.
Typically when Time parameters are used they are written for visual display, or for input into a data query.
The curly bracket syntax is used to determine the display format.
For example:
{TimeWindowStart}                     produces:                2008-03-26T16:17:13Z
While:
{TimeWindowStart:yyyy-MM-dd}  produces:                2008-03-26
{TimeWindowStart:dd/MMM/yy}  produces:                26/Mar/08
{TimeWindowStart:HH:mm:ss}      produces:                16:17:13
