Altair® Panopticon
Cross Tab Axes
Visualizations that support cross tabbing include the following settings for both the X and Y axes.
Setting
Leaf Bar Thickness
The width or height allocated to last component of the cross tab axis in pixels.
Leaf Label Angle
The angle of text of the last component of the cross tab axis.
Inner Bar Thickness
The width or height allocated to all of the other components of the cross tab axis in pixels.
Inner Label Angle
The angle of text to all of the other component of the cross tab axis.
Min Interval Length
The minimal interval in pixels between crosses tabbed visualizations.
Max Interval Length
The maximum interval in pixels between crosses tabbed visualizations.
Word Wrap
Determines whether to wrap the cross tab axis text.
Show All Column Levels
Determines whether space in the text axis should be allocated to all hierarchy levels, and whether visible or not.
