Creating a New Shape Palette
1. Click Add Palette .
A new shape palette displays (i.e., ShapePalette.0).
2. Click ShapePalette.<Number>.
The section expands to allow its definition.
3. Enter the shape palette Title and click .
4. To make this shape palette the default for the workbook theme, tap the Default Palette slider to turn it on.
NOTE |
The default shape palette can not be deleted.
5. To add the shapes, click .
You can either:
· click on a shape.
· click . Select one or more SVG files in the Open dialog box that displays.
The added shapes are displayed.
To delete a shape, click it’s corresponding Deleteicon.
6. Select the Defauilt Shape in the drop-down list.
7. Click the Save icon on the toolbar.
8. When saved, the notification is displayed.
The new shape palette is available in the Shape Palette drop-down list in the Shape variable when the workbook theme, where it is added, is used (i.e., Light).
