Creating Data Extract from Apache Cassandra
The Apache Cassandra connector allows connection to Apache and Datastax Cassandra instances, by executing a pre-defined CQL query, and retrieving the resulting data.
1. On the New Data Extract page, select Cassandra in the Connector drop-down list.
2. Enter the following information:
Property |
Description |
Host |
Apache Cassandra host address. |
Port |
Apache Cassandra host port. Default is 9042. |
KeySpace |
Namespace that defines data replication in nodes. |
User Id |
The username used to connect to the Apache Cassandra service. |
Password |
The password used to connect to the Apache Cassandra service. |
3. Select whether the parameters should be automatically enclosed in quotes, by checking the Enclose parameters in quotes box.
4. Enter the CQL Query, which can contain parameters in a similar manner to the database connector.
5. Click to save and display the details
of the data extract.
6. Click then
to display the data preview.
