ActiveMQ
Allows connection to Apache’s ActiveMQ message bus on a real-time streaming basis. Specifically, the connector allows Panopticon to subscribe to XML, JSON or FIX based messages that are published on topics. The data format itself is arbitrary, and consequently, the connection includes the message definition.
1. Select ActiveMQ from the Data Sources pane. The ActiveMQ Settings pane and the retrieved ActiveMQ source are displayed.
2. Enter the Name of the ActiveMQ
data source, then click .
3. Enter the following information:
Property |
Description |
Broker |
The location of the message broker. |
User Id |
The user Id that will be used to connect to the ActiveMQ service. |
Password |
The password to connect to the ActiveMQ service. |
Topic |
The topic or queue physical name. |
4. Check/uncheck the Use durable subscription box.
NOTE |
When connecting to a message bus, it is recommended to disable durable messaging. When it is enabled, this puts a heavier load to the server, and slows down the start and stop of subscriptions.
5. Check/uncheck Messages can contain partial data box.
6. Select the Message Type.
7. Select either the dot (.) or comma (,) as the Decimal Separator.
NOTE |
Prepend 'default:' for the elements falling under default namespace.
8. Click to the fetch the schema based
on the connection details. Consequently, the list of columns with
the data type found from inspecting the first ‘n’ rows of the input
data source is populated and the Save button is enabled.
9. You can also opt to load or save a copy of the column definition.
10. Click to add columns to the MQ connection
that represent sections of the message. Then enter or select:
Property |
Description |
Name |
The column name of the source schema. |
Fix Tag/JsonPath/Text Column Index/XPath |
The Fix Tag/JsonPath/Text Column Index/XPath of the source schema. |
Type |
The data type of the column. Can be a Text, Numeric, or Time |
Date Format |
The format when the data type is Time. |
Enabled |
Determines whether the message field should be processed. |
Filter |
Defined parameters that can be used as filter. Only available for JSON, Text, and XML message types. |
NOTE |
To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of lower case Fs. There can be no additional characters following them. For example: yyyy-MM-dd HH:mm:ss.ffffff
To
delete a column, check its or all the column entries, check
the topmost
, then click
11. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
12. For this section:
Refer to Define Real-Time Settings for more information.
13. Set the row limit of the data set.
14. Tap the Preview Selected Data Source slider to turn it on.
15. Click to display the data preview.
