Alerting
The Alerts function allows to notify you when the data in a visualization has met your predefined settings.
If alerts are required to be sent via email, the following properties must be configured first in the Panopticon.properties file.
Property
Alert
Attribute
alert.creation.only.by.administrators
Enable or disable whether only Administrators can create alerts.
Default Value
false
Property
Alert
Attribute
email.address
The email address where the alert will be sent from.
Default Value
Property
Alert
Attribute
email.password
The email password, if available.
Default Value
Property
Email
Attribute
email.host
The host name used by the email server.
Default Value
Property
Email
Attribute
email.port
The port number used by the email server.
Default Value
Otherwise, when trying to enable an alert, this error will be displayed:
Save the updated file and restart Tomcat.
