Bookmarking
Bookmarks are saved configurations of the active dashboard and workbook. A bookmark can be added, by authenticating, and clicking on the Bookmarks icon.
Bookmarks are not available with anonymous access workbooks.
Bookmarks do not save data, but do save:
q Dashboard
q Parameters
q Filters
q Breakdowns, Hierarchies, Visible Depth, and Drill Level
q Variables (Size, Color, X, Y, etc.).
Consequently, although the underlying data may change, a specific view of that data can be specified and bookmarked for future usage.
Bookmarks can be added and are available to all authenticated users of the workbook.
Bookmarks also generate a unique URL, which can be sent to another individual with access, allowing them to see exactly the same view of the selected dashboard.
New bookmarks can be added by clicking the New button.
A new instance of the bookmark is added in the Bookmarks pane.
Click the Modify icon to define the settings of the bookmark. The Bookmark Settings pane is displayed.
Property |
Description |
Modify Bookmark |
Display the Bookmark Settings pane for the modification of the bookmark settings. |
Update Bookmark
Update the bookmark settings. Click Yes on the notification message to update.
Create Bookmark |
Allows the creation of a new bookmark. |
Delete Bookmark |
Remove the bookmark. Click Yes on the notification message to delete the bookmark. |
Name |
Name of the bookmark. |
Description |
Description of the bookmark. |
Dashboard Parameters
Available dashboard parameters. NOTES:
For example, if the dashboard contains an Action Date Picker that defaults to now, and that same parameter value is excluded from the bookmark, then the Action Date Picker default value will be the value when the bookmark is opened.
Save |
Enabled when a change is made in the bookmark settings. Click to save. |
